Solaris Common Desktop Environment: User's Guide
To Change the Orientation of the Charts
By default, Performance Meter displays the performance charts horizontally (side-by-side). Depending on the number of parameters you monitor and the available space on your desktop, you may want to display them vertically.
  1. Choose Setup from the Options menu.
    Performance Meter displays the Setup dialog box.
  2. Select Vertical or Horizontal to specify the type of chart required.
  3. (Optional) Select the Show Limit Line checkbox if you want your charts to indicate the threshold value using a line.
  4. Click Apply when you are satisfied with the changes you have made.
    Performance Meter displays the performance information in the specified orientation.
