Solaris Common Desktop Environment: User's Guide
To Choose Line Charts or Area Charts
The optional chart displayed for each parameter can be one of the following types:
  1. Choose Setup from the Options menu.
    Performance Meter displays the Setup dialog box.
  2. Select the Solid choice button for area charts or the Line choice button for line charts.
  3. (Optional) Select the Show Limit Line checkbox if you want your charts to indicate the threshold value using a line.
  4. Click Apply when you are satisfied with the changes you have made.
    Performance Meter displays the information using the specified charts.
