Solaris Common Desktop Environment: User's Guide
Printer Jobs Application
The Printer Jobs application is the application you see when you open a single printer from the Front Panel. The Printer Jobs application is a simplified version of Print Manager that shows only a single printer instead of all the printers on your system. The functions that are available inside Printer Jobs work the same way as they do in Print Manager.
To Start the Printer Jobs Application
    Click the Printer control in the Front Panel.
Note -
The pscolor printer is only shown in the figure as an example of a printer that has been added to a system. It will not be on your subpanel.
