Solaris Common Desktop Environment: User's Guide
To Print Using the Front Panel
  1. Drag a single file or multiple files from File Manager to the Printer control in the Front Panel or to a Printer icon in the Personal Printers subpanel.
    The system then displays a Print dialog box for specifying print options. A Print dialog box appears for each file you drag to the Printer control.
    Graphic
    Note -
    pscolor will not show on your system. It is only included as an example of a printer that has been added to a system.
  2. Optional. Use the text fields in the Print dialog box to set additional print options. (See "Setting Print Options Using the Print Dialog Box".)
  3. Click OK in the Print dialog box to send the job to the printer.
