Solaris Common Desktop Environment: User's Guide
To Find a Process
  1. Type your search text into the Find drop-down box, or select a previously used search text from the Find drop-down list.
    Your search text should be a string of characters that is common to the process entries of all of the processes you want to display.
  2. Press Return to highlight the first occurrence of the search text below the current cursor position.
    The text can be in any of the fields in the process entry.
  3. Press Return to highlight the next occurrence, and so on.
  4. When you have found the required process entry, clear the Find field.
    Note -
    When you reach the end of the scrolling pane, search does not revert to the top of the list. Therefore, to ensure you search all processes, select the first process entry in the list before typing your search text in the Find box.
