You can change the window focus policy, how active windows are displayed, and where window icons are displayed.
Select the settings you want:
Point In Window To Make Active: Makes a window active when the mouse pointer enters it
Click In Window To Make Active: Makes a window active when the mouse pointer enters it and you click mouse button 1
To save your changes, click OK.
Click OK when asked to Restart the Workspace Manager.
Raise Window When Made Active: Select this if you want a partially concealed window to be brought to the top when it becomes active
Allow Primary Windows On Top: Select this if you want the main window to be displayed on top of secondary windows when you click the primary window
Show Contents During Move: Select this if you want to move the whole window during a window move instead of just moving the outline at first
