Solaris Common Desktop Environment: User's Guide
Power Management
If you select a blank background screen, and your hardware is capable of turning the power off, it does so to save energy.
To disable power management when using Solaris CDE, change the Style Manager's screen saver default blank screen to a screen pattern. It can also be disabled by running the following command in a terminal emulator window:
% xset s noblank
