Solaris Common Desktop Environment: User's Guide
Color Buttons
Your display type and the Number of Colors selection determine the number of color buttons that make up a palette. You will have two, four, or eight color buttons in the Color dialog box. The different color buttons in the palette control the colors used for different areas of the screen.
If you have eight color buttons, they will be used as follows (buttons numbered from left to right, top to bottom):
  1. Active window borders
  2. Inactive window borders
  3. Switch for workspace 1 and every fourth additonal workspace (workspace 5, 9, ...)
  4. Text and list areas
  5. Main window background and switch for workspace 2 and every fourth additional workspace (workspace 8, 12, ...)
  6. Dialog box background and menu bar and switch for workspace 3 and every fourth additional workspace (workspace 7, 11, ...)
  7. Switch for workspace 4 and every fourth additional workspace (workspace 6, 10, ...)
  8. Front Panel background
If you have four color buttons, they will be used as follows (buttons numbered from left to right):
  2. Window bodies:
    1. Inactive window borders
    2. Main window and dialog box backgrounds and menu bar
    3. Front Panel background
  3. Workspace switches and backgrounds
If you have two color buttons, they will be used as follows (buttons numbered from left to right):
  2. Everything else
