Solaris Common Desktop Environment: User's Guide
To Open Text Editor
  1. Open the Applications subpanel in the Front Panel and click the Text Editor control.
    Graphic
Text Editor can also be started from the command line by typing this command in a Terminal window:
dtpad filename &
The file name is optional.
Note -
If the path /usr/dt/bin has not been set in your .cshrc file, then type /usr/dt/bin/dtpad to run Text Editor from the command line.
