Solaris Common Desktop Environment: User's Guide
To Import Another User's Personal Dictionary
  1. Click Options in the Spelling Checker dialog box.
  2. Click Import in the Spelling Checker Options dialog box.
    The Spelling Checker Import dialog box is displayed.
    Figure 10-9 Personal Dictionary Import dialog box
  3. Select the dictionary you want to import in the Files list, or type the dictionary name in the Selection field.
  4. Press Return or click OK.
    Note -
    You can also double-click the dictionary name in the dialog box.
  5. In the dialog box that appears, choose whether you want to append the imported personal dictionary to your own personal dictionary, or overwrite your own personal dictionary with the imported one.
