Solaris Common Desktop Environment: User's Guide
To Format a Document
  1. Choose Settings from the Format menu.
    Figure 10-13 Format Settings dialog box
    Graphic
  2. Enter margins.
    The default left margin is 0 and the right margin is dynamically set to the width of the Text Editor window. Margins are specified as a number of character columns.
  3. Select left, right, justify (block style), or center alignment.
  4. Determine the scope of the formatting:
    • To format a single paragraph, place the cursor in the paragraph, then click Paragraph.
    • To format the entire document, click All.
  5. After closing the dialog box, choose Paragraph or All from the Format menu to apply the settings.
