Solaris Common Desktop Environment: User's Guide
Folder Location of Application Manager
Application Manager behaves much like File Manager. This is because Application Manager is a File Manager view of a special folder on your system used to gather registered applications. Ordinarily, you do not need to know the location of this special folder. However, its location may be useful to you if you are trying to troubleshoot problems.
Login Manager creates the Application Manager folder each time you log in. Its location is:
where special_folder_name is a name assigned by the system that is unique for your system and login name.
Caution - Caution -
You should never attempt to directly modify the special_folder_name folder from a command line.
