Solaris Common Desktop Environment: User's Guide
To Specify Fonts within a Resource File
For example, to change the fonts for the dtterm command in a resource file:
  1. Edit the Dtterm resource file in the /usr/dt/app-defaults/language directory.
    You can use either the class name (Dtterm) or the application name (dtterm) for a resource file of Dtterm.
    Also, setting the LANG environment variable alters the search path of resource files to include the /usr/dt/app-defaults/language directory, where language is the locale name.
    After setting the LANG environment variable, the search path for resource files would include the following two folders:
  2. Insert the font set you want to use at the bottom of the file.
    For example, to use a monospace font, put this line at the bottom of the file:
    dtterm -fn -dt-interface user-medium-r-normal-*-*-*-*
  3. Save the file.
