The input method style determines how pre-editing will occur. It is controlled by the XmNpreeditType resource. The syntax, possible values, and default value type of the XmNpreeditType resource are:
Syntax |
value[,value,...] |
Possible values |
OverTheSpot, OffTheSpot, Root, None |
Default value |
OverTheSpot, OffTheSpot, Root |
The string list, separated by a comma, specifies the priority order for this resource. The first value supported by the input method is used.
For more information, see the Solaris Common Desktop Environment: Advanced User's and System Administrator's Guide.
