When you change the size of a Terminal window, applications running in the window may not know about the resizing. Use this procedure to resize the application's output.
To resize the window contents, type the following at the command-line prompt:
eval `resize`
Note that resize is enclosed within a set of single close quotation marks rather than double quotation marks.
