Application Packaging Developer's Guide
Optional Package Components
Package Information Files
There are four optional package information files you can include in your package:
Each package information file should have an entry in the prototype file. See "Creating Information Files" for more information on creating these files.
Package Installation Scripts
Installation scripts are not required. However, you can provide scripts that perform customized actions during the installation of your package. An installation script has the following characteristics.
The four script types are as follows:
See "Creating Installation Scripts" for a more information on installation scripts.
