Make the directory containing your information files the current working directory.
Create a file named copyright with your favorite text editor.
Enter the text of the copyright message exactly as you want it to appear as your package is installed.
Save your changes and quit the editor.
Complete one of the following tasks.
If you want to create additional information files and installation scripts, skip to the next task, "How to Reserve Additional Space on a Target System".
If you have not created your prototype file, complete the procedure "How to Create a prototype File Using the pkgproto Command", and skip to Step 5.
If you have already created your prototype file, edit it and add an entry for the information file you just created.
Build your package.
See "How to Build a Package", if needed.
After you build the package, install it to confirm that it installs correctly and verify its integrity. Chapter 4, Verifying and Transferring a Package explains how to do this and provides step-by-step instructions on how to transfer your verified package to a distribution medium.
For example, a partial copyright message might look like:
Copyright (c) 1998 Company Name All Rights Reserved This product is protected by copyright and distributed under licenses restricting copying, distribution and decompilation. |
