Application Packaging Developer's Guide
Parameter Descriptions for the pkginfo Long Format
Table 4-2 describes the package parameters that can be displayed for each package. A parameter and its value are displayed only when the parameter has a value assigned to it.
Table 4-2 Package Parameters
Parameter
Description
ARCH
The architecture supported by this package.
BASEDIR
The base directory in which the software package resides (shown if the package is relocatable).
CATEGORY
The software category, or categories, of which this package is a member (for example, system or application).
CLASSES
A list of classes defined for a package. The order of the list determines the order in which the classes are installed. Classes listed first will be installed first (on a media by media basis). This parameter may be modified by the request script.
DESC
Text that describes the package.
EMAIL
The electronic mail address for user inquiries.
HOTLINE
Information on how to receive hotline help about this package.
INTONLY
Indicates that the package should only be installed interactively when set to any non-NULL value.
ISTATES
A list of allowable run states for package installation (for example, S s 1).
MAXINST
The maximum number of package instances that should be allowed on a machine at the same time. By default, only one instance of a package is allowed.
NAME
The package name, generally text describing the package abbreviation.
ORDER
A list of classes defining the order in which they should be put on the medium. Used by the pkgmk command in creating the package. Classes not defined in this parameter are placed on the medium using the standard ordering procedures.
PKGINST
Abbreviation for the package being installed.
PSTAMP
The production stamp for this package
RSTATES
A list of allowable run states for package removal (for example, S s 1).
ULIMIT
If set, this parameter is passed as an argument to the ulimit command, which establishes the maximum size of a file during installation. This applies only to files created by procedure scripts.
VENDOR
The name of the vendor who supplied the software package.
VERSION
The version of this package.
VSTOCK
The vendor-supplied stock number.
For detailed information about the pkginfo command, refer to the pkginfo(1) man page.
