Application Packaging Developer's Guide
Example--Obtaining Information With the pkgparam Command
For example, to display values only, use this command.
$ pkgparam SUNWcadap
none
/opt
US/Mountain
/sbin:/usr/sbin:/usr/bin:/usr/sadm/install/bin
/usr/sadm/sysadm
SUNWcadap
Chip designers need CAD application software to design abc
chips.  Runs only on xyz hardware and is installed in the usr
partition.
system
release 1.0
SPARC
venus980706083849
SUNWcadap
/var/sadm/pkg/SUNWcadap/save
Jul 7 1998 09:58
To display parameters and their values, use the following command.
$ pkgparam -v SUNWcadap
CLASSES='none'
BASEDIR='/opt'
TZ='US/Mountain'
PATH='/sbin:/usr/sbin:/usr/bin:/usr/sadm/install/bin'
OAMBASE='/usr/sadm/sysadm'
PKG='SUNWcadap'
NAME='Chip designers need CAD application software to design abc chips.
Runs only on xyz hardware and is installed in the usr partition.'
CATEGORY='system'
VERSION='release 1.0'
ARCH='SPARC'
PSTAMP='venus980706083849'
PKGINST='SUNWcadap'
PKGSAV='/var/sadm/pkg/SUNWcadap/save'
INSTDATE='Jul 7 1998 09:58'
Or, if you want to display the value of a specific parameter, use this format:
$ pkgparam SUNWcadap BASEDIR
/opt
For more information, refer to the pkgparam(1) man page.
