Install your package.
See "How to Install a Package on a Standalone or Server" or "How to Add a Package to a Diskless or AutoClient System's Root File System", if needed.
Display additional information about your package.
# pkgparam [-v] pkg-abbrev [param...] |
-v |
Displays the name of the parameter and its value. |
pkg-abbrev |
Is the name of a specific package. |
param |
Specifies one or more parameters whose value is displayed. |
If you are ready to go to the next task, see "How to Remove a Package" or "How to Remove a Package From a Diskless or AutoClient System".
For example, to display values only, use this command.
$ pkgparam SUNWcadap none /opt US/Mountain /sbin:/usr/sbin:/usr/bin:/usr/sadm/install/bin /usr/sadm/sysadm SUNWcadap Chip designers need CAD application software to design abc chips. Runs only on xyz hardware and is installed in the usr partition. system release 1.0 SPARC venus980706083849 SUNWcadap /var/sadm/pkg/SUNWcadap/save Jul 7 1998 09:58 $ |
To display parameters and their values, use the following command.
$ pkgparam -v SUNWcadap pkgparam -v SUNWcadap CLASSES='none' BASEDIR='/opt' TZ='US/Mountain' PATH='/sbin:/usr/sbin:/usr/bin:/usr/sadm/install/bin' OAMBASE='/usr/sadm/sysadm' PKG='SUNWcadap' NAME='Chip designers need CAD application software to design abc chips. Runs only on xyz hardware and is installed in the usr partition.' CATEGORY='system' VERSION='release 1.0' ARCH='SPARC' PSTAMP='venus980706083849' PKGINST='SUNWcadap' PKGSAV='/var/sadm/pkg/SUNWcadap/save' INSTDATE='Jul 7 1998 09:58' $ |
Or, if you want to display the value of a specific parameter, use this format:
$ pkgparam SUNWcadap BASEDIR /opt $ |
For more information, refer to the pkgparam(1) man page.
