Application Packaging Developer's Guide
How to Obtain Information With the pkginfo Command
  1. Install your package.
    See "How to Install a Package on a Standalone or Server" or "How to Add a Package to a Diskless or AutoClient System's Root File System", if needed.
  2. Display additional information about your package.
    # pkginfo [-x | -l] [pkg-abbrev]
    Displays package information in extracted format.
    Displays package information in long format.
    Is the name of a specific package. If omitted, the pkginfo command displays information about all installed packages, in the default format.
Where to Go Next
If you are ready to go to the next task, see "How to Remove a Package" or "How to Remove a Package From a Diskless or AutoClient System".
