PKG=case6 NAME=Case Study #6 CATEGORY=applications BASEDIR=/opt ARCH=SPARC VERSION=Version 1d05 CLASSES=build |
i pkginfo e build /sbin/inittab ? ? ? |
# PKGINST parameter provided by installation service # remove all entries from the existing table that # are associated with this PKGINST sed -e "/^[^:]*:[^:]*:[^:]*:[^#]*#$PKGINST$/d" /sbin/inittab || exit 2 if [ "$1" = install ] then # add the following entry to the table echo "rb:023456:wait:/usr/robot/bin/setup #$PKGINST" || exit 2 fi /sbin/init q || exit 2 exit 0 |
