Application Packaging Developer's Guide
The preinstall Script
The preinstall script initializes the prototype file, information files, and installation scripts for the backout package to be constructed. This script is very simple and the remaining scripts in this example only allow a backout package to describe regular files.
If you wanted to restore symbolic links, hard links, devices, and named pipes in a backout package, you could modify the preinstall script to use the pkgproto command to compare the delivered pkgmap file with the installed files, and then create a prototype file entry for each non-file to be changed in the backout package. The method you should use is similar to the method in the class action script.
The scripts patch_checkinstall and patch_postinstall are inserted into the package source tree from the preinstall script. These two scripts undo what the patch does.
# This script initializes the backout data for a patch package
# directory format options.
#       @(#)preinstall 1.5 96/05/10 SMI
# Copyright (c) 1995 by Sun Microsystems, Inc.
# All rights reserved
PATH=/usr/sadm/bin:$PATH
recovery="no"
if [ "$PKG_INSTALL_ROOT" = "/" ]; then
        PKG_INSTALL_ROOT=""
fi
# Check to see if this is a patch installation retry.
if [ "$INTERRUPTION" = "yes" ]; then
    if [ -d "$PKG_INSTALL_ROOT/var/tmp/$Patch_label.$PKGINST" ] || [ -d \
"$PATCH_BUILD_DIR/$Patch_label.$PKGINST" ]; then
        recovery="yes"
    fi
fi
if [ -n "$PATCH_BUILD_DIR" -a -d "$PATCH_BUILD_DIR" ]; then
        BUILD_DIR="$PATCH_BUILD_DIR/$Patch_label.$PKGINST"
else
        BUILD_DIR="$PKG_INSTALL_ROOT/var/tmp/$Patch_label.$PKGINST"
fi
FILE_DIR=$BUILD_DIR/files
RELOC_DIR=$BUILD_DIR/files/reloc
ROOT_DIR=$BUILD_DIR/files/root
PROTO_FILE=$BUILD_DIR/prototype
PKGINFO_FILE=$BUILD_DIR/pkginfo
THIS_DIR=`dirname $0`
if [ "$PATCH_PROGRESSIVE" = "true" ]; then
        # If this is being used in an old-style patch, insert
        # the old-style script commands here.
        #XXXOld_CommandsXXX#
        exit 0
fi
# Unless specifically denied, initialize the backout patch data by
# creating the build directory and copying over the original pkginfo
# which pkgadd saved in case it had to be restored.
if [ "$PATCH_NO_UNDO" != "true" ] && [ "$recovery" = "no" ]; then
        if [ -d $BUILD_DIR ]; then
                rm -r $BUILD_DIR
        fi
        # If this is a retry of the same patch then recovery is set to
        # yes. Which means there is a build directory already in
        # place with the correct backout data.
        if [ "$recovery" = "no" ]; then
                mkdir $BUILD_DIR
                mkdir -p $RELOC_DIR
                mkdir $ROOT_DIR
        fi
        # Here we initialize the backout pkginfo file by first
        # copying over the old pkginfo file and themn adding the
        # ACTIVE_PATCH parameter so the backout will know what patch
        # it's backing out.
        # NOTE : Within the installation, pkgparam returns the
        # original data.
        pkgparam -v $PKGINST | nawk '
                $1 ~ /PATCHLIST/        { next; }
                $1 ~ /PATCH_OBSOLETES/  { next; }
                $1 ~ /ACTIVE_OBSOLETES/ { next; }
                $1 ~ /Obsoletes_label/  { next; }
                $1 ~ /ACTIVE_PATCH/     { next; }
                $1 ~ /Patch_label/      { next; }
                $1 ~ /UPDATE/   { next; }
                $1 ~ /SCRIPTS_DIR/      { next; }
                $1 ~ /PATCH_NO_UNDO/    { next; }
                $1 ~ /INSTDATE/ { next; }
                $1 ~ /PKGINST/  { next; }
                $1 ~ /OAMBASE/  { next; }
                $1 ~ /PATH/     { next; }
                { print; } ' > $PKGINFO_FILE
        echo "ACTIVE_PATCH=$Patch_label" >> $PKGINFO_FILE
        echo "ACTIVE_OBSOLETES=$ACTIVE_OBSOLETES" >> $PKGINFO_FILE
        # And now initialize the backout prototype file with the
        # pkginfo file just formulated.
        echo "i pkginfo" > $PROTO_FILE
        # Copy over the backout scripts including the undo class
        # action scripts
        for script in $SCRIPTS_DIR/*; do
                srcscript=`basename $script`
                targscript=`echo $srcscript | nawk '
                        { script=$0; }
                        /u\./ {
                                sub("u.", "i.", script);
                                print script;
                                next;
                        /patch_/ {
                                sub("patch_", "", script);
                                print script;
                                next;
                        { print "dont_use" } '`
                if [ "$targscript" = "dont_use" ]; then
                        continue
                fi
                echo "i $targscript=$FILE_DIR/$targscript" >> $PROTO_FILE
                cp $SCRIPTS_DIR/$srcscript $FILE_DIR/$targscript
        done
        # Now add entries to the prototype file that won't be passed to
        # class action scripts. If the entry is brand new, add it to the
        # deletes file for the backout package.
        Our_Pkgmap=`dirname $SCRIPTS_DIR`/pkgmap
        BO_Deletes=$FILE_DIR/deletes
        nawk -v basedir=${BASEDIR:-/} '
                BEGIN { count=0; }
                        token = $2;
                        ftype = $1;
                $1 ~ /[#\!:]/ { next; }
                $1 ~ /[0123456789]/ {
                        if ( NF >= 3) {
                                token = $3;
                                ftype = $2;
                        } else {
                                next;
                { if (ftype == "i" || ftype == "e" || ftype == "f" || ftype == \
"v" || ftype == "d") { next; } }
                        equals=match($4, "=")-1;
                        if ( equals == -1 ) { print $3, $4; }
                        else { print $3, substr($4, 0, equals); }
                ' < $Our_Pkgmap | while read class path; do
                        # NOTE: If pkgproto is passed a file that is
                        # actually a hard link to another file, it
                        # will return ftype "f" because the first link
                        # in the list (consisting of only one file) is
                        # viewed by pkgproto as the source and always
                        # gets ftype "f".
                        # If this isn't replacing something, then it
                        # just goes to the deletes list.
                        if valpath -l $path; then
                                Chk_Path="$BASEDIR/$path"
                                Build_Path="$RELOC_DIR/$path"
                                Proto_From="$BASEDIR"
                        else    # It's an absolute path
                                Chk_Path="$PKG_INSTALL_ROOT$path"
                                Build_Path="$ROOT_DIR$path"
                                Proto_From="$PKG_INSTALL_ROOT"
                        fi
                        # Hard links have to be restored as regular files.
                        # Unlike the others in this group, an actual
                        # object will be required for the pkgmk.
                        if [ -f "$Chk_Path" ]; then
                                mkdir -p `dirname $Build_Path`
                                cp $Chk_Path $Build_Path
                                cd $Proto_From
                                pkgproto -c $class "$Build_Path=$path" 1>> \
$PROTO_FILE 2> /dev/null
                                cd $THIS_DIR
                        elif [ -h "$Chk_Path" -o \
                             -c "$Chk_Path" -o \
                             -b "$Chk_Path" -o \
                             -p "$Chk_Path" ]; then
                                pkgproto -c $class "$Chk_Path=$path" 1>> \
                        else
                                echo $path >> $BO_Deletes
                        fi
                done
fi
# If additional operations are required for this package, place
# those package-specific commands here.
#XXXSpecial_CommandsXXX#
exit 0
