If your software product might be installed on older versions of the SunOS operating system, the request script needs to do all the necessary work. This approach can also be used to manipulate multiple directories. If additional directories are required, they still need to be included under a single base directory in order to provide an easily administrable product. While the BASEDIR
parameter does not provide the level of granularity available in the latest Solaris release, your package can still walk the base directory by using the request script to manipulate parametric paths. This is how the pkginfo and pkgmap files might look.
# pkginfo file PKG=SUNWstuf NAME=software stuff ARCH=sparc VERSION=1.0.0,REV=1.0.4 CATEGORY=application DESC=a set of utilities that do stuff BASEDIR=/opt SUBBASE=SUNWstuf VENDOR=Sun Microsystems, Inc. HOTLINE=Please contact your local service provider EMAIL= MAXINST=1000 CLASSES=none daemon PSTAMP=hubert980707141632 |
: 1 1758 1 d none $SUBBASE/EZstuf 0775 root bin 1 f none $SUBBASE/EZstuf/dirdel 0555 bin bin 40 773 751310229 1 f none $SUBBASE/EZstuf/usrdel 0555 bin bin 40 773 751310229 1 f none $SUBBASE/EZstuf/filedel 0555 bin bin 40 773 751310229 1 d none $SUBBASE/HRDstuf 0775 root bin 1 f none $SUBBASE/HRDstuf/mksmart 0555 bin bin 40 773 751310229 1 f none $SUBBASE/HRDstuf/mktall 0555 bin bin 40 773 751310229 1 f none $SUBBASE/HRDstuf/mkcute 0555 bin bin 40 773 751310229 1 f none $SUBBASE/HRDstuf/mkeasy 0555 bin bin 40 773 751310229 1 d none /etc ? ? ? 1 d none /etc/rc2.d ? ? ? 1 f daemon /etc/rc2.d/S70dostuf 0744 root sys 450 223443 1 i pkginfo 348 28411 760740163 1 i postinstall 323 26475 751309908 1 i postremove 402 33179 751309945 1 i preinstall 321 26254 751310019 1 i preremove 320 26114 751309865 1 i i.daemon 509 39560 752978103 1 i r.daemon 320 24573 742152591 |
This example is not perfect. A pkginfo -r command returns /opt for the installation base, which is pretty ambiguous. Many packages are in /opt, but at least it is a meaningful directory. Just like the previous example, this next example fully supports multiple architectures and versions. The request script can be tailored to the needs of the specific package and resolve whatever dependencies are applicable.
