BASEDIR
ParameterThe checkinstall script can select the appropriate base directory at install time, which means that the base directory can be placed very low in the directory tree. This example increments the base directory sequentially, leading to directories of the form /opt/SUNWstuf, /opt/SUNWstuf.1, and /opt/SUNWstuf.2. The administrator can use the pkginfo command to determine which architecture and version are installed in each base directory.
If the SUNWstuf package (containing a set of utilities that do stuff) uses this method, its pkginfo and pkgmap files would look like this.
# pkginfo file PKG=SUNWstuf NAME=software stuff ARCH=sparc VERSION=1.0.0,REV=1.0.4 CATEGORY=application DESC=a set of utilities that do stuff BASEDIR=/opt/SUNWstuf VENDOR=Sun Microsystems, Inc. HOTLINE=Please contact your local service provider EMAIL= MAXINST=1000 CLASSES=none daemon PSTAMP=hubert980707141632 |
: 1 1758 1 d none EZstuf 0775 root bin 1 f none EZstuf/dirdel 0555 bin bin 40 773 751310229 1 f none EZstuf/usrdel 0555 bin bin 40 773 751310229 1 f none EZstuf/filedel 0555 bin bin 40 773 751310229 1 d none HRDstuf 0775 root bin 1 f none HRDstuf/mksmart 0555 bin bin 40 773 751310229 1 f none HRDstuf/mktall 0555 bin bin 40 773 751310229 1 f none HRDstuf/mkcute 0555 bin bin 40 773 751310229 1 f none HRDstuf/mkeasy 0555 bin bin 40 773 751310229 1 d none /etc ? ? ? 1 d none /etc/rc2.d ? ? ? 1 f daemon /etc/rc2.d/S70dostuf 0744 root sys 450 223443 1 i pkginfo 348 28411 760740163 1 i postinstall 323 26475 751309908 1 i postremove 402 33179 751309945 1 i preinstall 321 26254 751310019 1 i preremove 320 26114 751309865 1 i i.daemon 509 39560 752978103 1 i r.daemon 320 24573 742152591 |
