Programming Utilities Guide
Unknown Targets
If a target is named either on the command line or in a dependency list, and it
Then make stops processing and issues an error message.
$ make believe
make: Fatal error: Don't know how to make target `believe'.
Note -
However, if the -k option is in effect, make continues with the other targets that do not depend on the one in which the error occurred.
