Programming Utilities Guide
Pattern-Replacement Macro References
A pattern-replacement macro reference is similar in form and function to a suffix replacement reference. You can use a pattern-replacement reference to add or alter a prefix, suffix, or both, to matching words in the value of a macro.
Note -
As with pattern-matching rules, pattern-replacement macro references are not available in earlier versions of make.
A pattern-replacement reference takes the form:
$(macro:p%s =np%ns)
where p is the existing prefix to replace (if any), s is the existing suffix to replace (if any), np and ns are the new prefix and new suffix, and % is a wild card. The pattern replacement is applied to all words in the value that match `p%s. For instance:
SOURCES= old_main.c old_data.c moon
OBJECTS= $(SOURCES:old_%.c=new_%.o)
all:
        	@echo $(OBJECTS)
produces:
$ make
new_main.o new_data.o moon
You can use any number of % wild cards in the right-hand (replacement) side of the = sign, as needed. The following replacement:
OBJECTS= $(SOURCES:old_%.c=%/%.o)
would produce:
main/main.o data/data.o moon
Note, however, that pattern-replacement macro references should not appear in the dependency line of the target entry for a pattern-matching rule. This produces a conflict, since make cannot tell whether the wild card applies to the macro, or to the target (or dependency) itself. With the makefile:
OBJECT= .o
x:
x.Z:
        	@echo correct
%: %$(OBJECT:%o=%Z)
it seems as if make should attempt to build x from x.Z. However, the pattern-matching rule is not recognized; make cannot determine which of the % characters in the dependency line to use in the pattern-matching rule.
