Programming Utilities Guide
Checking Out a File for Editing: sccs edit
To edit a source file, you must check it out first using sccs edit. (The sccs edit command is equivalent to using the -c option to sccs get.)
SCCS responds with the delta ID of the version just retrieved, and the delta ID it assigna when you check in your changes.
$ sccs edit program.c
1.1
new delta 1.2
87
You can then edit it using a text editor. If a writable copy of the file is present, sccs edit issues an error message; it does not overwrite the file if anyone has write access to it.
