Programming Utilities Guide
Attributes
Attributes are characteristics by which you identify probe points in your code. Table 1-3 lists the predefined attributes. You can add more attributes with the TNF_PROBE macros. See "Using the TNF_PROBE Macros".
Table 1-3 Predefined Attributes
Attribute
Characteristics
Value
enable
A probe point performs the action that it is set up for only if it is enabled. For example, even when the tracing state is set, tracing occurs only if the probe point has been enabled.
OFF (default)
file
The name of the file containing the probe point.
work.c
funcs
Shows the list of probe functions connected to this probe. Currently, only the debug function is available.
<no value> (default)
keys
The groups to which the probe point belongs. If any key in a probe point is enabled, then that probe point is enabled.
work_module
work
line
The line number in the code on which the probe point occurs.
10
name
The name of the probe point.
work_start
object
The name of the shared object or executable that the probe is in. Useful for selecting all the probes in a particular module.
work
slots
The names of the probe point arguments (arg_name_n), see page 41.
int_input
string_input
trace
When tracing for a probe point is on, a line is written to the trace file each time the probe point is executed in your program.
ON (default)
