Programming Utilities Guide
Failure of Event-Writing Operations
A few failure points, like system call failures, are possible when writing events to trace files. These failures result in a failure code being set in the target process. The target process continues normally (but no trace records are written).
Whenever a user types Control-c to prex to get to a prex prompt, prex checks the failure code in the target and informs the user if there was a tracing failure.
