Programming Utilities Guide
TNF_PROBE_1 Through TNF_PROBE_5
The numbers 1 through 5 in the argument names are used here to illustrate the number of variables you give to the probe point. For example, the syntax for TNF_PROBE_1 is:
TNF_PROBE_1(name, keys, detail,
arg_type_1, arg_name_1, arg_value_1);
and the syntax for TNF_PROBE_5 is:
TNF_PROBE_5(name, keys, detail,
arg_type_2, arg_name_2, arg_value_2
arg_type_3, arg_name_3, arg_value_3
arg_type_4, arg_name_4, arg_value_4
arg_type_5, arg_name_5, arg_value_5);
The arguments are:
Table 1-9 Predefined Types
Type
Associated C Type and Semantics
tnf_long
int, long
tnf_ulong
unsigned int, unsigned long
tnf_longlong
long long (if implemented in compilation system)
tnf_ulonglong
unsigned long long (if implemented in compilation system)
tnf_float
float
tnf_double
double
tnf_string
char *
tnf_opaque
void *
For example, the cookie.c program on "A Sample C Program" uses TNF_PROBE_2 as follows:
TNF_PROBE_2(inloop, "cookie main loop","sunw%debug in the loop",
				tnf_long, loop_count, 		i,
				tnf_long, total_iterations, 	sum);
Table 1-10 explains some of the macro definitions in cookie.c.
Table 1-10 TNF Macro Definitions in cookie.c
TNF_PROBE_0 (
A probe with no argument types
start,
The name of the probe
"cookie main",
The list of groups the probe belongs to cookie and main (the values of the keys attribute)
"sunw%debug starting main");
User-defined attribute=sunw%debug; value=starting main (used by debug probe function)
TNF_PROBE_2 (
A probe with two variables
inloop,
"cookie main loop",
The keys - cookie, main, and loop
Values for the debug probe function
tnf_long,
The type of the first variable
loop_count,
The name of the first variable (value of the slots attribute)
i,
The first variable
tnf_long,
The type of the second variable
total_iterations,
The name of the second variable (value of the slots attribute)
sum);
The second variable
