Programming Utilities Guide
Tracing, Enabling, and Connecting
To trace at a probe point, the probe point must have trace on and it must be enabled. To debug at a probe point, the probe point must be connected to the debug function and must be enabled.
Table 1-6 shows which combinations of tracing, enabling, and connecting result in which actions.
Table 1-6 Tracing, Enabling, and Connecting Actions
Enabled or Disabled
Tracing State (On/Off)
Debug State (Connected/Cleared)
Results In
Enabled
On
Connected
Tracing and Debugging
Enabled
On
Cleared
Tracing only
Enabled
Off
Connected
Debugging only
Enabled
Off
Cleared
Nothing
Disabled
On
Connected
Nothing
Disabled
On
Cleared
Nothing
Disabled
Off
Connected
Nothing
Disabled
Off
Cleared
Nothing
