STREAMS Programming Guide
Extended Signals
To let a process obtain the band and event associated with SIGPOLL more readily, STREAMS supports extended signals. For the given events, a special code is defined in <sys/siginfo.h> that describes the reason SIGPOLL was generated. Table 3-5 describes the data available in the siginfo_t structure passed to the signal handler.
Table 3-5 Data in siginfo_t Structure
Event
si_signo
si_code
si_band
si_errno
S_INPUT
SIGPOLL
POLL_IN
Band readable
Unused
S_OUTPUT
SIGPOLL
POLL_OUT
Band writable
Unused
S_MSG
SIGPOLL
POLL_MSG
Band signaled
Unused
S_ERROR
SIGPOLL
POLL_ERR
Unused
Stream error
S_HANGUP
SIGPOLL
POLL_HUP
Unused
Unused
S_HIPRI
SIGPOLL
POLL_PRI
Unused
Unused
