STREAMS Programming Guide
Message Processing
Typically, put procedures are required in pushable modules, but service procedures are optional. If the put routine queues messages, there must exist a corresponding service routine that handles the queued messages. If the put routine does not queue messages, the service routine need not exist.
Example 7-3 shows typical processing flow for a put procedure which works as follows:
Figure 7-10 shows typical processing flow for a service procedure that works as follows:
Caution - Caution -
A service or put procedure must never block since it has no user context. It must always return to its caller.
If no processing is required in the put procedure, the procedure does not have to be explicitly declared. Rather, putq(9F) can be placed in the qinit(9S) structure declaration for the appropriate queue side to queue the message for the service procedure. For example:
static struct qinit winit = { putq, modwsrv, ...... };
More typically, put procedures process high-priority messages to avoid queueing them.
Device drivers associated with hardware are examples of STREAMS devices that might not have a put procedure. Since there are no queues below the hardware level, another module does not call the module's put procedure. Data comes into the Stream from an interrupt routine, and is either processed or queued it for the service procedure.
A STREAMS filter is an example of a module without a service procedure — messages passed to it are either passed or filtered. Flow control is described in "Flow Control in Service Procedures".
The key attribute of a service procedure in the STREAMS architecture is delayed processing. When a service procedure is used in a module, the module developer is implying that there are other, more time-sensitive activities to be performed elsewhere in this Stream, in other Streams, or in the system in general.
Note -
The presence of a service procedure is mandatory if the flow control mechanism is to be utilized by the queue. If you don't implement flow control, it is possible to overflow queues and hang the system.
