STREAMS Programming Guide
The FIONREAD ioctl returns the number of data byte (in all data messages queued) in the location pointed to by the arg parameter. The ioctl returns a 32-bit quantity for both 32-bit and 64-bit application., Therefore, code that passes the address of a long variable needs to be changed to pass an int variable for 64-bit applications.
