STREAMS Programming Guide
STREAMS Module Configuration
Like device drivers, STREAMS modules are dynamically linked and can be loaded into and unloaded from the running kernel.
Note -
The word module is used differently when talking about drivers. A device driver is a kernel-loadable module that provides the interface between a device and the Device Driver Interface, and is linked to the kernel when it is first invoked.
A loadable module must provide linkage information to the kernel in an initialized modlstrmod(9S) and three entry points: _init(9E), _info(9E), and _fini(9E).
STREAMS modules can be unloaded from the kernel when not pushed onto a Stream. A STREAMS module can prevent being unloaded by returning an error (selected from errno.h) from its _fini(9E) routine (EBUSY is a good choice).
