STREAMS Programming Guide
Perimeter options
Several flags are used to specify the perimeters. These flags fall into three categories:
The inner perimeter is controlled by these mutually exclusive flags:
The presence of the outer perimeter is configured using:
Recall that by default all synchronous entry points enter the inner perimeter exclusively and enter the outer perimeter shared. This behavior can be modified in two ways:
