STREAMS Programming Guide
Manipulating Modules
With STREAMS you can manipulate modules from user application level, interchange modules with common service interfaces, and change the service interface to a STREAMS user process. These capabilities yield further benefits when working with networking services and protocols:
The following examples show the benefits of STREAMS capabilities for creating service interfaces and manipulating modules. These examples are only illustrations and do not necessarily reflect real situations.
Protocol Portability
Figure 1-6 shows how an X.25 protocol module can work with different drivers on different machines by using compatible service interfaces. The X.25 protocol module interfaces are Connection Oriented Network Service (CONS) and Link Access Protocol - Balanced (LAPB).
Figure 1-6 Protocol Module Portability
Graphic
Protocol Substitution
You can use alternate protocol modules (and device drivers) on a system if the alternates are implemented to an equivalent service interface.
Protocol Migration
Figure 1-7 shows how STREAMS can move functions between kernel software and front-end firmware. A common downstream service interface lets the transport protocol module be independent of the number or type of modules below it. The same transport module will connect without modification to either an X.25 module or X.25 driver that has the same service interface.
By shifting functions between software and firmware, you can produce cost-effective, functionally equivalent systems over a wide range of configurations. This means you can swiftly incorporate technological advances. The same transport protocol module can be used on a lower-capacity machine, where economics preclude the use of front-end hardware, and also on a larger scale system where a front-end is economically justified.
Figure 1-7 Protocol Migration
Graphic
Module Reusability
Figure 1-8 shows the same canonical module (for example, one that provides delete and kill processing on character strings) reused in two different Streams. This module would typically be implemented as a filter, with no service interface. In both cases, a TTY interface is presented to the Stream's user process since the module is nearest the Stream head.
Figure 1-8 Module Reusability
Graphic
