Common Desktop Environment: Help System Author's and Programmer's Guide
To Create a General Help Dialog
  1. Include the appropriate header files:
    #include <Help.h>
     #include <HelpDialog.h>
  2. Create an instance of the general help dialog widget:
    • Use the DtCreateHelpDialog() convenience function.
      Or, use the XtCreateManagedWidget() function.
  3. Add a callback for handling hyperlink events that occur within the dialog. (For more information, see "Responding to Hyperlink Events".)
  4. Add a close callback for handling the Close command.
The following code segment creates a general help dialog (as a child of parent) using the convenience function. The dialog is left unmanaged--presumably it is managed elsewhere in the application when a help request is made.
Widget   mainHelpDialog, moreButton, helpButton;
 ac = 0;
 XtSetArg (al[ac], XmNtitle,  "My Application - Help");  ac++;
 XtSetArg (al[ac], DtNhelpVolume,  "My Help Volume");  ac++;
 XtSetArg (al[ac], DtNlocationId,  "Getting Started");  ac++;
 XtSetArg (al[ac], DtNhelpType,  "DtHELP_TYPE_TOPIC");  ac++;
 mainHelpDialog =
   DtCreateHelpDialog (parent,  "mainHelpDialog", al, ac);
The following two calls add the hyperlink and close callbacks to the dialog. Presumably, the functions HyperlinkCB() and CloseHelpCB() are declared elsewhere in the application.
XtAddCallback (mainHelpDialog, DtNhyperLinkCallback,
 				HyperlinkCB, (XtPointer)NULL);
 XtAddCallback (mainHelpDialog, DtNcloseCallback,
                CloseHelpCB, (XtPointer)NULL);
See Also
