Common Desktop Environment: Help System Author's and Programmer's Guide
To Create a Quick Help Dialog
  1. Include the appropriate header files:
    #include <Help.h>
     #include <HelpQuickD.h>
  2. Create an instance of the quick help dialog widget:
    • Use the DtCreateHelpQuickDialog() convenience function.
      Or, use the XtCreateManagedWidget() function.
  3. Add a callback for handling hyperlink events that occur within the dialog. (For more information, see "Responding to Hyperlink Events".)
  4. Add a close callback for handling the OK button.
  5. Configure the dialog buttons that you want to use:
    • If you intend to use the application-configured button, manage it and add an activate callback.
    • If you want to disallow printing, unmanage the Print button.
    • Manage the Help button and add a help callback to the dialog to allow the user to get help on help.
The following code segment creates a quick help dialog (as a child of parent) using the convenience function. The dialog is left unmanaged; presumably, it is managed elsewhere in the application when a help request is made. In this example, the application-configured button is enabled and used to request more help.
Widget   quickHelpDialog, moreButton, helpButton;
 ac = 0;
 XtSetArg (al[ac], XmNtitle,  "My Application - Help");  ac++;
 XtSetArg (al[ac], DtNhelpVolume,  "My Help Volume");  ac++;
 XtSetArg (al[ac], DtNlocationId,  "Getting Started");  ac++;
 XtSetArg (al[ac], DtNhelpType,  "DtHELP_TYPE_TOPIC"); ac++;
 quickHelpDialog =
   DtCreateHelpQuickDialog (parent,  "quickHelpDialog", al, ac);
The following two calls add the hyperlink and close callbacks to the dialog. Presumably, the functions HyperlinkCB() and CloseHelpCB() are declared elsewhere in the application.
XtAddCallback (quickHelpDialog, DtNhyperLinkCallback,
				HyperlinkCB, (XtPointer)NULL);
XtAddCallback (quickHelpDialog, DtNcloseCallback,
                CloseHelpCB, (XtPointer)NULL);
Here, the application-configured button is managed and assigned an activate callback that invokes the application's MoreHelpCB() function.
moreButton = DtHelpQuickDialogGetChild (quickHelpDialog,
 XtManageChild (moreButton);
XtAddCallback (moreButton, XmNactivateCallback,
                MoreHelpCB, (XtPointer)NULL);
To provide "help on help," the dialog's Help button is managed and a help callback is added to the dialog.
helpButton = DtHelpQuickDialogGetChild (quickHelpDialog,
 XtManageChild (helpButton);
XtAddCallback (quickHelpDialog,DtNhelpCallback,
                HelpRequestCB, USING_HELP);
Like other OSF/Motif dialogs, when you add a help callback to a quick help dialog, it is used by both the F1 key and the Help button.
See Also
