Common Desktop Environment: Help System Author's and Programmer's Guide
HelpTag Software
The HelpTag software can be invoked automatically by double-clicking a help source file in File Manager or by running the dthelptag command manually in a terminal window.
Helptag does two significant tasks:
  1. The HelpTag parser converts your marked-up files into an internal format (Semantic Delivery Language) understood by the Help System. If you've made any markup errors, the errors are reported in a file named volume.err.
  2. If there are no parser errors, the master help volume file (volume.sdl) is created.
