Common Desktop Environment: Help System Author's and Programmer's Guide
To Run the dthelpview Command Manually
    If the volume.sdl file for the volume you want to display is either in the current directory or has been registered, execute this command:
dthelpview -helpVolume volume.sdl
Or, if the volume.sdl is in another directory (and hasn't been registered), execute this command:
dthelpview -helpVolume /full-path/volume.sdl
The -helpVolume parameter can be shortened to -h in any of these commands.
