Common Desktop Environment: Help System Author's and Programmer's Guide
Application Help
If you are writing help for an application, you need to decide which topics are browsable and which topics are available from the application as context-sensitive help. A topic is browsable if you can navigate to it using the topic tree or hyperlinks. Topics designed exclusively for context-sensitive help might not be browsable because the only way to display the topic may be from within a particular context in the application.
You must also decide if you want your application's help volume to be registered. Registered help volumes can be displayed by other applications (such as the Help Viewer), making the information more widely accessible. If another help volume contains hyperlinks to topics in your help volume, your help volume must be registered.
See "Registering Your Application and Its Help" for information about installing and registering your application.
