Common Desktop Environment: Help System Author's and Programmer's Guide
Display the Help Volume
From the build subdirectory, double-click the voiceact.sdl file icon.
This displays the help volume using the desktop Help Viewer. You can now scroll the information and jump to related information by choosing hyperlinks.
Note -
You can run the Help Viewer manually in a terminal window.
To do so, execute the following command. It displays the new help volume.
dthelpview -h voiceact.sdl
See Also
