Common Desktop Environment: Help System Author's and Programmer's Guide
Syntax
<term baseform [gloss | nogloss]>text<\term>
Or:
<term baseform [gloss | nogloss]|text|
Or:
++text++
Where:
baseform
The form of the term as it appears in the glossary if it is not the same as used in the text. This difference can occur, for example, when the term is used in the text in its plural form but appears in the glossary in its singular form. If the term includes spaces or special characters, put the baseform string in quotes.
gloss
Default. Requests that HelpTag verify that the term is in the glossary.
nogloss
Omits the term from the glossary; however, the term is formatted in a bold font.
The shorthand form uses two ++ (plus signs) before and after the glossary term.
Note -
If your help volume does not include a glossary, use the nogloss parameter.
When HelpTag processes the help volume, warning messages are issued to indicate glossary terms that were not marked with the nogloss parameter and do not have corresponding definitions in the glossary.
Tagging a term with the <term> element automatically creates a hyperlink to the glossary. If there is no glossary, the link will not work.
A <\term> end tag is required if the long form is used.
