Common Desktop Environment: Help System Author's and Programmer's Guide
Defined term: Identifies a term and the term's definition within the glossary.
  <dterm>first term
   definition of first term
   <dterm>Nth term
   definition of Nth term
This element is used within the <glossary> section.
The name of the term follows the <dterm> tag and appears on the same line. The term's definition begins on the line following the <dterm> tag.
An end tag is not required.
The following markup defines the first two words in a glossary:
 A mathematical rule or procedure for solving a problem.
 To press and release a mouse button.
See Also
