Common Desktop Environment: Help System Author's and Programmer's Guide
<caution>
Caution notice: Specifies information that warns the user about a potential loss of data or hazard.
Syntax
<caution>
text of caution
 <\caution>
The default heading is "Caution". To specify a different heading, use the <head> tag as shown here:
<caution><head>alternate heading
text of caution
<\caution>
The <\caution> end tag is required.
To specify that an icon be displayed with the caution, define a file entity at the top of your help volume as follows:
<!entity CautionElementDefaultIconFile FILE  "filename">
Where filename is the name of the icon graphic. A sample caution icon named cauticon.pm is provided in the /usr/dt/dthelp/dthelptag/icons directory.
Example
Here is a caution message:
<caution>
There is no Undo for this selection. Before performing this task,
save any changes to your document.
 <\caution>
The markup produces this output:
Graphic
See Also
