Common Desktop Environment: Help System Author's and Programmer's Guide
Help volume title: Specifies the title of the help volume.
<title>help volume title
The <title> element is an optional element in the <metainfo> (meta information) section. It is recommended, however, because the title provides the volume name displayed in the help dialog boxes.
The <title> follows immediately after the <metainfo> tag. Because the title of the volume may be displayed by other applications (information viewers, for example) that may not be able to format the title, you should use only plain text within the title.
The <\title> end tag is not required.
Here is a sample volume title:
<title>The Super Hyperlink User's Guide
See Also
