Common Desktop Environment: Help System Author's and Programmer's Guide
Note: Creates a special format which attracts attention to text that makes an important point.
 text of note
The default heading for the note is "Note". To specify a different heading, use the <head> element.
If you want an icon to appear with the note, define NoteElementDefaultIconFile in an <!entity ...> declaration.
The default note icon named note is located in the /usr/dt/dthelp/dthelptag/icons directory.
The <\note> end tag is required.
See Also
