Common Desktop Environment: Help System Author's and Programmer's Guide
Syntax
<esc>text<\esc>
Or:
<esc|text|
Note -
If the long form is used, the text cannot contain the three-character sequence <\x (the less-than symbol followed by a backslash followed by a letter). If the short form is used, the text cannot contain the |(vertical bar) character.
If you use the first syntax, the <\esc> end tag is required.
